I have seen a lot of threads on risers, but not seen anyone successfully install 2" risers, so I thought I might share what I did. I'm loving the new riding position.
Initially I thought I would, at the very least, need a longer clutch cable and a longer front brake hose. Actually, none of this is required. I am using all original cables and hoses and have installed a riser with a 2" height gain, and also 1" offset to reduce reach. It's in the attached pictures, and was bought from Fleabay. This one.
To install them successfully I first removed the right hand side cover. this gave me access to completely take out the clutch cable and re route it more directly, and also have it pop out behind the triple tree, not within the wire cable guide (I bent it out of the way slightly) - overall, the absolutely shortest possible route. One of the attached pics shows where I cable tied it to keep it off the engine; the only tie needed. That's all that's needed for the left hand side and leaves the clutch cable with sufficient play to go lock to lock..
On the right hand side, with several cables and a brake hose I chose to completely remove the wire cable guide, and also cut the big rubber grommet off of the brake hose. To remove the guide it was necessary to unbolt the front cowl (4 bolts), and separate the two parts (two pop out plastic clips on the rear top corner of the cowl. This doesn't completely remove it from the bike but just about provides access to unbolt the wire cable guide. With that done I was able to manipulate the guide and remove it without disconnecting and cables or hoses, and without damaging the guide. That's all that is needed. Without the guide there is much more freedom in the right hand cables and hoses. I can turn the steering lock to lock without excessive tension on anything.
That's all there is to it, apart from putting the bike bits back together. Lovely - job done!
