1 - 3 of 3 Posts
2015 CB300F
Not used to having to check oil on Hondas but this one uses a bit. Was down a fair bit and could hear it tho I had a couple thousand K km on it since I got it ...was somewhat overfull when purchased.
Was barely registering when tipped past vertical when I checked yesterday. Topped it off. Happier motor.
Does not seem to burn oil ...my previous Suzuki rides tended to kick out some oil via the breather when run at speed for a day.
Any feedback appreciated.
How many K's you got on that sucker macdoc? As a rule these things are typical Honda build quality and dont burn oil until high mileages. No sign of any leaks anywhere on the engine? Run your finger around the exit hole on the muffler and see if there's any oily residue.
2015 CB300F
Thanks. 30k km ...will try the getting intimate with the exhaust. ;)
Will check on drips.
It's likely due for major service. Put it off due to quote.
1 - 3 of 3 Posts
