I would not start the engine. I would not change the oil filter. Remove the oil drain plug and leave it open for a good while so the cold fluids have time to completely drain. I wouldn't expect any further problems.
Do you think the oil I poured in made it to the filter? Or does oil only get pulled through the filter when the engine runs?I would not start the engine. I would not change the oil filter. Remove the oil drain plug and leave it open for a good while so the cold fluids have time to completely drain. I wouldn't expect any further problems.
Water always goes to the bottom when mixed with oil because its more dense in structure so it should be sitting in the bottom of your sump ready to come out when you pull the bung. If you haven't started the engine and started pumping the oil around then you should be fine as Airhead said, but for the sake of a 10 buck filter personally I would change it out.Do you think the oil I poured in made it to the filter? Or does oil only get pulled through the filter when the engine runs?
Thanks
What Kiwi Rider said... I never argue with his expertise and wisdom.Do you think the oil I poured in made it to the filter? Or does oil only get pulled through the filter when the engine runs?
Thanks
