This rack DOES NOT FIT THE CB300FA without modification.
I removed the rear faring to make measurements, but after cutting the pieces indicated on the drawing and pictures, and re-installing the faring the rack fitted right into the space where the rear grab handles were removed.
New hole were drilled to move the rack back 1/4 inch to the rear of the motorcycle.
If you make these modifications, especially the ones marked second cut, you should be able to slip the rack into the spot to see what else you have to cut away.
The end result looks good tho, you did well. Isn't it a pain when stuff that's supposed to fit your model doesn't.:mad:
