1 - 2 of 2 Posts
I was all set to finally bleed my brakes after 7,000 miles. Is there a trick with these screws? I'm halfway towards stripping them completely. I've tried different size Philips and flatheads. Nothing works. Do I need a specific Japanese screwdriver or what?
It's always the easiest-sounding parts of a job that end up going wrong, isn't it?
Yes if you want to latch onto them correctly then you require a JIS screw driver (Japanese Industrial Standard) , very similar to Phillips screwdrivers but have a smaller centre point profile.
Since it sounds like you are already half way gone though try this trick: Get someone to tap the end of your screw driver with a hammer as you twist and push down on it at the same time. Might be just enough to shock the thread loose.
1 - 2 of 2 Posts
