Basic Tools:
- Metric Hex Keys - 4,5, & 6mm
- Metric Combination & Box End Wrenches - 6,8,10,12,14,17,19, & 24mm
- Metric Sockets - Six Point, Standard & Deep - 1/4" Drive: 6,8, & 10mm - 3/8" Drive: 10,12,14,17,19, & 24mm
- 1/4" & 3/8" Drive Standard Ratcheting Handles
- 1/4" & 3/8" Extensions (various lengths, including wobble type)
- 1/4" Drive Ratcheting Driver Handle ("T" or screwdriver style)
- 3/8" Drive Breaker Bar or T-Bar Handle
- 3/8" Drive Torque Wrench (click type)
- Honda Spark Plug Socket Wrench - P/N 89216-MAT-000
- Japanese Industrial Standard Screwdrivers
- Needle Nose Pliers, Standard & Long Reach
- Slip Joint Pliers, Standard
- Hammers: Dead blow; Plastic/Rubber Head; Ball Peen
- Punch Set
- Snap-On Pick Set
- Rear Shock Spanner
- Angled Feeler Gauge Set, Tapered Blades
- Digital Multimeter
- Battery Tender (or other small charger suitable for motorcycle batteries)
- Flexible LED Inspection Light
- Small Inspection Mirror
- Utility Knife (and extra blades)
- Ruler & Tape Measure
- Long Reach Tweezers
- Magnetic Pickup Tool
- Control Cable Lubrication Tool
- Chain Breaker Tool
- Plastic Bristle Chain Cleaning Brush & Toothbrushes
- Small Long Reach Funnel
- Clear Vinyl Hose (small diameter, for bleeding brake calipers)
- Oil Drain Pan, Clean Drain Pan/Containers (for engine coolant, brake bleeding, etc.)
- Tire Pressure Gauge (dial or digital)
- Tire Valve Chuck, Blower Attachment, Air Hose
- Small Air Compressor (1.5 HP, 2 Gal., 120 PSI)
- Heavy Duty Tie Downs, Soft Hooks, & HD Eye Lag Bolts (to suspend front end of bike from garage rafters, for front suspension work)
- Rear Wheel Paddock Stand
- Model Specific Factory Service Manual
- Notebook & Pens/Pencils
Expendable Supplies:
- Anti-Seize Compound (for frequently removed bolt & screw threads, and other applications)
- Loctite Thread Lock, Medium & High Strength (for specific applications)
- Water Proof Wheel Bearing Grease
- High-Temp Black RTV Silicone
- Handgrip Cement
- DOT 4 Brake Fluid
- Aerosol Brake Cleaner
- Engine Coolant
- O-Ring Safe Chain Lubricant
- Kerosene (for drive chain & misc. parts cleaning)
- WD-40 Spray Lubricant
- Paint Pen, White or Yellow (for marking critical torqued fasteners)
- Shop Towels (paper & cloth)
- Oil Absorbent "Pig Mat" (or plastic sheeting, for oil filter changes and lubing drive chain)
- Latex Gloves and/or Hand Cleaner
- Punch Set
- Snap-On Pick Set
- Handgrip Cement
- DOT 4 Brake Fluid
- Engine Coolant
