1 - 12 of 12 Posts
I pinched this mod of a member on the 250R forum and did it to my old repsol.
It's only taken me 15 months to get round to doing it to my 300R. :)
This is one for the fettlers and tinkerers who have access to a dremel or are patient with a round file.
Basically when Honda manufacture the header pipe and weld the larger diameter flange (that fits into your engines head) onto the end of the actual pipe, they leave a raised weld that hinders the flow of exhaust gases exiting the exhaust port. See photo.
So if your fussy like myself you can remove this weld and allow a smoother passage for the gases which at high revs in particular aids efficiency. It will end up looking like this:
OK, so it's a bit like fitting the K&N air filter, you know it helps but its not going to transform your bike instantly into an arm stretching beast!
Folk who race bikes say it's the sum of a lot of small improvements that makes the difference.
Foot note: Make sure you replace the copper exhaust gasket when you re-fit the header pipe, they are cheap as chips.
Nice tip Kiwi
A job for the spring weather me thinks :)
another advantage of the single,,
only one pipe to deal with..
no need to rationalise caring for your motorcycle[!]
a definition of rational, to any motorcyclist..
Kiwi, what dremel attachment did you use for this?. My exhaust is already showing surface rust at 4k right on the front section about 3-4 inches where my fender ext doesn't cover. Ordered some PJ1 exhaust paint and will remove exhaust completely and respray but thought I might do this mod.
Great catch! If I already hadn't swapped my stock for a new header I would have done this.
Ahh the exact reason I changed mine to Stainless Steel right away. Everyone said why bother. Well it's ugly, weighs a ton and it rusts. :laugh:
Would love to but there not as available here in blighty and they cost a lot more, if Honda had put a decent fender on it there wouldn't be a problem, also its a workhorse, Ive put levers on and pegs and am waiting for delivery of an R&G exhaust hanger and blanking plate to put on. I had to let a Scorpion exhaust for a 250 go on ebay this morning, it sold for £107. Scorpion refused to sell me a link pipe for my 300 otherwise I would have bidded for it, cant justify £300+ for an exhaust on the country roads I ride on.
Scorpion are one company I won't be using if that's their after sales service.
Discussion Starter #10
I used a cylindical shaped hardened steel one of 10 - 12mm diameter. If you were patient you could use a grinding stone type one. It took me about 5 - 10 minutes.
2015 CBR300R
How difficult is it to remove and re attach that longer exhaust piece? it's really rusted on mine, I painted the OEM slip on exhaust with black engine paint and it looks FANTASTIC, it's Held with three coats for one year too. But that longer tube is just nasty. I was thinking of removing it, sanding it, and painting it with brake caliper red (900°f), is that the right temp paint? Also, excellent mod, I'll be doing it while the pipe is removed.
1 - 12 of 12 Posts
