Trying to install a new ignition switch on my 2016 CB300F after someone tried to steal it and absolutely f*cked my ignition up past the point of getting a key in. Looking for something that wont take forever to get here internationally but can’t seem to find any. Is there any other ignition switches that are compatible with the CB300F? Possibly from a CBR300? Only problem I’ve found is that id have to splice on a 3 prong connection for the four, but dont want to shove a switch in that isn’t compatible.
I mean, they look pretty damn identical tbh
Have you looked at a schematic and part numbers from a Honda OEM parts vendor? Sometimes a part used on several different models or years will use the same number.. sometimes not. But a quick check shows the 2016 and 2018 CB300f both use the same "combination and lock switch assembly" (part 2 in schematic). If you like, you can change and toggle through as many years and models as are listed to compare. Good Luck.
