1 - 15 of 15 Posts
Hi everyone, this isn't exactly a write up since I forgot to take pictures of the process of taking apart the headlight assembly. This is more of a journal documenting my experience with an LED Headlight. This is the first time I've installed one. It was not difficult at all, it was pretty straight forward.
There are 4 bolts and two plastic rivets, once removed the headlight separates from the housing. Remove the rubber seal on the headlight, release the lock and remove the old bulb, insert the new one, lock, rubber, and its done.
I had to cut a slit on the boot to slide it over the heat sink on the back of the bulb, I don't think I've compromised the waterproofing and if I notice any moisture in my headlight I will figure something else out, until then it seals pretty well.
I wasn't paid to do a review so I'm not going to name drop which bulb I bought, but it was advertised to be rated at 3500 Lumens and 40 Watts. It's color temperature is 6500k. The light is very bright, way brighter than the stock headlight. Similar to putting an HID in regular housing, the cutoff is nonexistent. Aka very bad. The lowbeam LED outputs a similar amount of light to the stock halogen on High.
Lots of pics so I uploaded them all to a gallery.
It was still daytime outside so until it gets darker it's just garage pics, sorry. I haven't seen how it looks on the street yet.
Here are the pics.
Let me know if you guys have any questions!
What you see is the general problem with replacing a bulb with another where the location of the source of the light is in a different position.
As long as you do not drive at night, that's not a problem. But at night, you will likely dangerously pi$$ off the drivers in front of you. As other wrote about lights, too bright a front light might prevent the car drivers from seeing your turn signals.
That said, thanks for sharing the info, photos... That's nice, and the light is clearly "stronger", although 40W for LED seems quite high. That would be the equivalent of 150W halogen, something like that. So I would guess that either the light is not efficient, or the Chinese manufacturer is quoting the total for 2 bulbs? The last option is that your light is really equivalent of 150W halogen lights (roughly 3 times what you had before). :)
I have the cbr300r and yesterday I decided to switch my headlights to the led bulb as well.
the only problem was the base of the bulb was huge and the rubber gasket for the housing and that spring clip just barely went back on to hold the new bulb in. now I need to figure out a way to secure the wires hanging out and keep the housing from getting moisture in it...
Here are the pics.
I do agree 40watts for a LED bulb is quite high. Does it have little Chip LED's on each bulb? How many? I thought LED's didn't get that hot? Have you felt the heat sink after having the light on for a bit? Just wondering if the heat sink gets real hot if the rubber seal over it can withstand the heat
Completely forgot to mention there's a fan at the back of the heatsink and it's always on and kinda loud.
I did a bit of reading up on other people's experiences with replacing halogens with LEDs earlier so I managed to find one that has the LED emitters located in about the same places as the filaments of a halogen, and include the little reflector cups under the front emitters too. This is for my wife's CB300FA which uses a single H4 headlight.
I actually purchased two pairs of these headlights since we have a few bikes to put these into, I already did a brief writeup at another bike forum but here are the pictures for the CB300FA. Each pair was about USD$30 shipped, so the price was right.
First picture shows the bulbs we purchased. Box says 8000 lumens for the pair so it should be 4000 lumens each. I'm guessing these are Chinese lumens but the bulb is no doubt brighter than the stock halogen. Based on the product code, I'm guessing these bulbs run 25W, but I don't know if that is for the pair or for each bulb.
Next two are the stock halogen low and high beams.
The two after that are the LED low and high beams. The beam patterns and cutoffs are fairly similar by my eye, but I had my camera flash on which produced some artifacts with the capture. The LED is definitely brighter than the stock halogen, and much more white.
Next two are a close-up of the installed LED, and a shot of the bike with the electricals on. Looks good. Next I just need a LED flasher relay and some replacement LED bulbs for those indicators... are they BAUS15 sockets?
I'm replying to this post to 'bump' it to the top as it got lost in the approval required issue we had recently.
Instead of just replacing the stock bulb in the turn signals why don't you just buy a new set of led signals? IMO the leds are brighter and look better as there are usually 8-15 leds in 1 signal.
I put a HID system with Morimoto projectors on my R and the cutoff is perfect. They sell projectors for HID and the stock Halogens, but not sure if they have projectors for LED's. I am actually just putting my bike together because I opened up my headlights to put new angel COB LED angel eyes in.
Thanks kiwi rider for the approval and bump!
I forgot to mention, the LED headlights I bought use a passive heatsink, so there is no noisy cooling fan (and one less moving part). I had originally purchased a newer version with the copper ribbon heatsink which is supposedly much more effective, but was told by the seller there were some QC issues and so I was given these older ones with the solid heatsink instead.
We might be weird but we would kind of like to keep it looking mostly stock, as aerodynamically inefficient as that may be, so I continue the search for the BAU15S LED replacement bulbs. I agree the Asian HID projectors with the halo are utterly badass though.
That looks good. Cut off appears to be close to stock. Could you take a photo in the dark, also at a wall?
I'll see what I can do, will probably have to wait until Saturday night. I park in a lit underground parkade so I need to find a suitable wall somewhere dark...
Here's what I was able to do. Didn't want to stay out too long. First set are low and high beam with camera flash on, next two with camera flash off. This was just auto mode, I'm wondering if I should have used a night mode with a longer exposure or something but my camera should have automatically figured it out...
Once again for reference this is on a CB300F with just the single H4 LED bulb.
1 - 15 of 15 Posts
