Hey,
I’ve seen some forums on here with guys talking about putting a 15t grin sprocket in their bikes but I can’t seem to find one available anywhere if any one know where I can find a 15t front sprocket for a 2018 cbr300r I’d really appreciate it.
Front sprocket CBR300.
Pitch: 520 Fitting: Narrow Spline Inner Diameter Minimum: 18.4 mm Inner Diameter Maximum: 21.6 mm Internal Teeth (Number of Teeth): 11 Number of mounting bolts: 2 Hole Spacing: 17 /19 mm Width: 7.1 mm Type:
Tyga Performance
PBI Sprockets model 382 .
Also note that they are the same sprockets as used on , CB-300F 2015, CBR-300R 2015. So look for those too. Amazon got mine from Sunstar who make the OEM 14T.
Places that DON't make 15T sprockets (to save your time - 14T seems the max).
JT Sprockets Model JTF1321
Renthal
A 15T will make the bike much nicer to ride. Had one on my CBR300 and first thing I did when I got the CB300R was fit a 15T.
Hey,
[/Q
Hey,
If you can't find one I got one I'll let you have for $15 postage paid
Thank you every one for the suggestions I went ahead and found a sunstar and got it on but I’m noticing the chain cover doesn’t want to fit anymore with that 36115 sprocket on the bike
The metal insert (“case saver”) inside it needs to be removed or slightly clearanced. I am super OCD about inspecting my chain, so I just took it out. It can help prevent case damage (theoretically) if the chain gets loose, skips, or breaks though. When I went back to the 14, I just bought a new cover. They’re cheap.
If you remove the case saver you need to space the cover out a bit to get it to fit right-two small washers on each screw work good
