By 'starter' I assume you mean starter relay rather than starter motor. Probably not either esp starter motor. With the symptoms you describe it sounds like your battery is flat again so maybe you have a battery drain going on. Or a bad battery terminal connection. Do you have a multi meter so you can check your battery voltage?
