1 - 20 of 46 Posts
So, the grom destroys all in terms of people expending many times the original purchase price on modding. As such there's a ton more people researching all options etc.
I started looking at the grom as they have the same 33pin keihin ecu as our cbr300r. Ive downloaded the service manuals for both, and most of the wires go to the same pins. All the ones that fuel controllers intercept do at least.
As such ive purchased a grom pcv. It has a patch loom which plugs inbetween stock ecu and harness. As long as all wires are patched across and it intercepts the fuel inj, 2 crank wires, tps, ign. It should work.
The grom inj has the same imp and voltage.
The grom also has the same issue with the stock ecu controlling afrs 0-60% throttle. The 2 things they do to work around it is the dunojet wideband 2. It can simulate a modified narrow band signal to your stock ecu to give a 13.5afr.
The other is even cheaper. An EFIE which is stand alone and intercepts and modifies the O2 signal. O2 sensor on the Grom and piggyback tuners - Page 9
As the stock ecu runs rich enough in open loop +80% just putting in the EFIE will richen up your afrs in the closed loop area. Tho you'd need a wideband to know how much etc and set it up correctly.
One more thing. They have found the stock ecu is quite capable of running a larger inj. It will adjust to pull your afrs back done.
Anyhow. Wish me luck with the pcv. I want ign control.:devil:
Not easy being a pioneer, we're all counting on you, good luck. :D
Am I missing something? Why did you go for the Grom PCV instead of one for the 300's? Is it my understanding that the Grom PC is a simple piggyback verse our PC has to be connected to all the sensors separately? There are some people on the CRF forum that use a CB400 injector
There is no pcv for the cbr250/300r except the limited production that jettuning did but dont do anymore, despite their website listing them still.
PcVs are and always have been piggybacks. How they intercept the signals varies from bike to bike. Some intercept at the sensors, the grom one intercepts via apatch loom at the ecu like most car intercept ecus. Ie greddy emanage.
The only thing dynojet offers for our bikes is the fc which is a fuel controller only.
All ejk, aftrplus, bazzaz zfi, pcV, dfc, two bros are piggyback systems. How they intercept and alter the stock ecu signals varies.
Also, i think the throttle body could do with enlarging. There are a few that do tjis to your stock TB. How much bigger we can get ours i dont know yet. Ill have to buy a spare and see how much meat there is. Max bore quote 135usd free shipping. 240ish aud from efi hardware in aus.
Both custom make the butterfly once theyve bored out your throttle body.
Heres some quick figures.
Crf250l 36mm TB 20hp
Take kit 28hp you can see how restricted the crf is. Unless factory ecm is also super restrictive
Cbr250r 38mm TB 25hp
Take kit 35hp
Crf250r 46mm TB 40hp 11000rpm obv has bigger valves and cam specs.
I was simply asking if the Grom version was only a PGM-FI ECU piggyback? Versus the other PC that piggy backs to all sensors except the 1 spliced TPS wire. Bazzaz has an ECU only piggyback and EJK has a Fuel Injector only piggyback. I have all the PDF's for different brand FC's for the 300 so I know how they install. That's all I was asking as to why you went with the Grom PCV.
I thought I had seen it for sale back when I as looking for FC's but you're saying they don't make them anymore for the 300? I have a friend in my riding group with a PCV on his 300f, he loves it
*edit I see some sites do say discontinued on the PCV but I have found some sites with it still in stock(or so they say)
Was there an issue they had? Why did they discontinue them?
This site says in stock $276 + free shipping(us only maybe?)
https://www.maniacmotorsport.com/pr...KkG0cSa9qrMaUQwE7na12-2NPxFSMRUg-CRoCtubw_wcB
The pcV for the cbr250/300r was only ever available through jettuning. Not even direct from dynojet.
So are you asking what sensors the grom pcv intercepts at the ecu?
As the grom pcv does fuel and ign, it would intercept/monitor the fuel injector, tps, coil, and crank sensors.
Pcvs all piggy back of the same sensors, it doesnt matter if it intercept the wires just before they get to the ecu or just after the sensors, the end result is the same.
The bazzaz doesnt do ign timing. And its a mess to install compared to the plug and play of the pcv.
Initially i looked at the crf250r version but their tb has seperate sensors for map and tps, and the crank sensor is 6 wire plug.
Have you looked for the PCV from any other vendor? Unless there was an issue with it as to why you wouldn't want it? there are still some available here in the states. Probably leftover supply but they are still selling it. Did you see the link I gave? Is that the PCV or regular PCFC? The part # is 16-024
Jet Tuning says it's only available exclusively through them but many other sites sell them
Here's another U.S. vendor
https://www.kmsperformance.com/shop/showcart.aspx?task=view
16024 is the pcfc and i think youll find that is all those online places have. Its not a pcv
Power Commander Motorcycle Fuel Injection Tuning Module
Those 2 pictures are both of patch harness type connections. You unplug the ecu, then one plug connects to the wiring loom and the other back into you ecu.
Then these Online sites are falsely advertising the PCV then. They describe the V and the photos of the product show the PCV
the PCFC part # is FC16-024
the PCV is #Item #:pCV_16-024
Discussion Starter · #12 ·
Well either jettuning and dynojet are lying or the websites are or just dont know the difference.
Discussion Starter · #13 · (Edited)
Anyhow, recieved the PCV today. Undid the tape surrounding where they tapped into wires etc to trace/check which wires were connected to what. There are 8 wires coming from the PCV altogether.
These wires are just tapping in. (Pcv wire colours not factory loom)
Red pin 1-IGP (battery or ignition)
Bl/W pin 4-SG (wire supplys power to sensor unit on the throttle body)
Grey pin 5-THL (throttle position)
Black pin 10-PG2 (earth)
W/bl pin 12-PCP (crank trigger)
Br/W pin 23-PCM (crank trigger)
These last 2 wires are intercepted. The wires a different colour leading from loom to PCV to the one going from the PCV to the ecu.
G in, W/G out pin 11-IGPLS (coil)
O in, W/O out pin 16-IJN (injector)
All other wires are left alone for the factory ecu to communicate with everything else. (Bank angle sensors, tacho, water temp etc)
Now i just to plug it in, connect laptop and check its all working i guess...
Discussion Starter · #16 ·
Next issue to overcome is the groms lower rpm limit. It has rev extend but i believe its still limited to 9250 or 9750, i forget.
Grom only has 4, and the pcv does gear mapping so not sure if i can just recalibrate speed and gearing.
Ill email dynojet and see how helpful they will be. Afaik i cant just load a cbr250r map onto a grom pcv.
Discussion Starter · #18 ·
I also purchased the wideband 2. So once i get a new header, ill get the Wideband sensor bung welded in, then hopefully with its sorcery will give me a 13.5afr in the closed loop area of the std ecus mapping. Then i can tweak the ign timing across the borad and fuel in the 80%+ tps area.
Interestingly enough, the preloaded grom map removes fuel, much like the bazzaz map i posted somewhere else.
Ill try get it on the dyno before tweaking to give an idea of how its running now, then get it properly tuned after the recall works been done with a 13:1cr wiseco piston and takegawa cams.
Wow good job haha
Discussion Starter · #20 ·
Wow, just got an email back from jettuning saying they canget them again. I believe dynojet isnt making them have a minimum order of 10 anymore.
I find it amusing that this happens after i emailed dynojet with links to this thread etc im sure its just coincedence tho.
But yeh, if I'd waited barely a week i wouldn't have any guess work. That said, the bonus of the wb2 from hardracing is its presetup to give the altered stock O2 sensor.
I'm not sure how the jettuning pcvs work around the O2 on peoples cbr250r.
I might need to join their forums and ask.
1 - 20 of 46 Posts
