1 - 3 of 3 Posts
Hello, my dear friends,
I bought about year ago imported cbr300 2015 from the UK. Previous owners fell with it or had accidents, the machine was repaired well according to the first service check. Now I am seeing (attached picture) a leak on the engine, should I be worried? also right bottom fairing is a bit oily (also can be seen in the picture), but the engine cover from that side is not covered by oil, did you meet any similar problems? Thank you for your replies
It appears to be a leak from the gasket between the crank case and the cylinder barrel. This wont be cheap to fix as replacing the thin gasket requires quite a lot of engine dismantling. Just keep an eye on it and worry about it if it starts dripping on the garage floor!
The lower right fairing is under an engine breather and can, over time, collect an oily deposit. Agree with Kiwi about the leak on the engine.
1 - 3 of 3 Posts
