1 - 5 of 5 Posts
Since there isn't a category for brakes, I think it fits best in the wheels/tires/suspenion.
Got a front steel braided line. Before putting it on I wanted to compare the OEM so I bleed the brakes, since it is still pretty new and not 5 or 10 years old. I got this bike used with a few hundred miles and the brake fluid was already dark. Looking at mfg. date it is 7/14 so the fluid has been in there for almost two years. It was orginally purchased 9/14 and I got it 5/15. Normally I bleed my brakes every year after the rainy season. So when I got it the brake felt kinda...well not much of a feel to them but wasn't spongy. So I wanted to know how they would be with fresh fluid. Most folks that put on steel braided lines always claim that they make a huge difference, I think they do but not as huge as folks think. What folks are feeling is a used up oem line along with used up fluid of course when you put on a new line and fresh fluid it'll feel better..even if it is a oem replacement line. So after the bleeding the brakes felt much firmer and had more feel to them, just as I thought. Every time I bleeds brakes they always feel better. So after test riding that I put on the new braided lines and they feel a little better, firmer with more feel. There was enough of a difference that I felt it but it wasn't hugely different. The difference in feel from oem line to braided line is like the difference in bleeding the brakes every year. Now if I had gone from the used up fluid to the new braided line and fresh fluid then it would feel much more different.
Stock line is 32 1/4" from end of fitting to end of fitting. New line is about 3/4" longer, end of fitting to end of fitting. Line I got was 30", fittings added about 3". Both ends of fitting are 30*. Reused the two mounting bracket but had to get some tubing to shim/grommet new line on brackets. I'll make a video soon to show what it looks like.
Got some videos but can't make youtube embed. Link is my signature.
@DaBinChe I'm reviving this old thread just to ask you a question. I am putting on front and rear stainless hoses, fast bleeders and new banjo bolts too. I haven't taken anything apart yet I like to have all the parts first. So I haven't been able to see the Pitch size of the stock Banjo bolts. I know they are M10x22, do you know if they are 1.25? That seems to be the size Honda uses on other bikes I've seen.
Thanks!
Isn't pitch for Honda bleeder 1.25?
Here's a part number:Speed Bleeder SB8125
Yes that is the pitch for the speed bleeders, I already have Stainless Steel speed bleeders. I need to know the pitch for the Banjo bolts. I want to order Titanium Banjo bolts but Honda only shows they are m10x22. Honda uses 1.25 pitch for m8 bolts but for m10 the standard is 1.50, but I don't know about Honda because the rear sprocket bolts are m10 and they were 1.25 pitch
1 - 5 of 5 Posts
