Aside from sprockets,
You think it's possible in an easy way, to change the gears on a Cb300f/cbr300r from within the gearbox?
I'd be intrigued to know, if such a practice is possible or not...
In an easy way?
No... splitting the cases on a motorcycle engine is not an easy undertaking, particularly if one doesn't have access to all the special tools required for the job.
As for swapping out the gears themselves, I don't know if you could even find anything that would fit besides the same OEM gears that Honda originally installed in the gearbox. Plus, it's not like there is a lot of extra room inside the cases of motorcycle gearbox... everything is packed into a pretty tight space.
I thought this would be the case.
On a rebel, it's pretty easy to open the case, and see the gears and clutch right there.
I thought perhaps there's a way to just swap out one or two gears with a different ratio, affecting all others, but alas...
I suggest you do your self a favor and stick to sprocket changes. What you are contemplating doing is a major undertaking...:eek:
unless you know a lot about gears and mating and fitment i wouldn't even think of attempting this. I'm a fitter/machinist and it's not something i'd ever consider, because the outlay vs gains would be terrible.
Sprocket changes are quick and easy and work.
Yeah,
Most bikes are pretty flexible in sprockets.
The CB300s are not.
15/34T is the highest sprocket gearing that fits...
Even if I wanted 15/29 (will make 5th gear top speed, and 6th gear city riding at 40mph very good in mpg)
I guess I could also fit a higher profile tire, but they usually do very little to the overall gearing (aka 1mph difference over 50mph, or a few ten less rpms on 5000).
Here is one more with energy !
Hi I see that 250 and 300 have the same 6 gear sprocket but reverse.!
300. 27/26, 250 26/27. If the gearbox is the same, but with different config.
There should be 2 types of both 26 and 27 with or whidout ( tabs? ) name it for me.
So if You put in the 250:s sprocket in the 300.
You can have an 13 T front sprocket, and still have the gearing
for commuting like orginal 14.
And in my case I do not need to go to 15 in the front
beacuse now I con crusing little softer, using 6 gear.
Happy riding !
