1 - 8 of 8 Posts
I find that mine is more comfortable cruising in the 5-6K range. However, in order to have some power available I usually have to keep it around 7-8K.
I cruise in the 4-5K range. Although above 45MPH, I'm stuck going above that range
I'm new to motorcycle riding, so perhaps the 6K redline on my cage has kept me conservative
Ive changed my gearing so that when I'm cruising at the 100 kph speed limit (62 mph) I'm only pulling 5800 rpm which feels more relaxed.
I dont think the 300R motor is as naturally free revving as the 250R motor.
Kiwi rider, what spocket changes did you do to achieve 5800 rpm at 100km/h? Have you checked your speedo is accuate? I believe I read on here somewhere that you had put on a 15 tooth front sprocket, can you give me the manufacturer and part number if that sprocket as I can not get one so far in Australia.
Hi Joe, I first changed the front to 15T then changed the rear to 34T (standard is 36T) just to lower the revs a bit more. I am a lightweight tho.
So do the front first and see how you feel.
Your possibly having trouble sourcing a sprocket if you are asking for one for a CBR300. I usually ask for CBR250 products as they have the same running gear and are more commonly available. The 15T front sprocket is a common as pig $hit in australasia as its the same one as they use on the XR250's.
However.... if your still having trouble sourcing one I have included a link to the outfit I got mine from in NZ. They freight to Oz as well.
Honda CBR250R (2013) parts, from Motozone | NZ?s Leading Motorcycle Online Store
Scroll down to Power Transmission > sprocket - front - alternative gearing. Its the bottom one on the list of three, product # SPF206715C. This is a NZ made sprocket. Make sure you change the box at the top of the page to AUD first. Good outfit to deal with. All the best.
Cool. I thought you must have changed more to achieve the lower revs.. would you believe that I also have an XR 250 so might have a sproket laying around to check. Thanks for the help. Honda dealers here said that the cbr250 was different as it had a different part number. I think from what you have told me I should be able to sort it from here.
cheers
kiwi
Yeah its amazing how little some of the dealers know about basic stuff. I couldn't source a smaller sprocket for the rear locally tho, but I could get bigger (38T 40T etc) so I got one from the states.
I've also got an '04 XR250, must be one of the most common trail bikes down under, and for good reason.
Ive had a couple of XR200's as well, got a good run out of all of them, hard to beat Hondas for reliability.
On city streets I will usually do a conservative 4-5k rpm, but on the freeway I'll be in the 7-8k range at about 65-75 mph.
1 - 8 of 8 Posts
